Carbon\Carbon::createFromTimestamp(): Argument #1 ($timestamp) must be of type string|int|float, null given, called in /sites/deploy/4.5.1_revanjordan/lib/Xmds/Soap.php on line 1377
Head to Administration → Settings → Defaults →
Disable the following setting: “Should Layouts be automatically Published?”
It’s a bug in version 4.5.1
It’s not the only one related to null values passed to createFromTimestamp(), another big one is in lib/Helper/DateFormatHelper.php
replace around line 55
public static function createFromTimestamp($timestamp): Carbon
return Carbon::createFromTimestamp($timestamp, date_default_timezone_get());
with:
if (!is_null($timestamp)) {
return Carbon::createFromTimestamp($timestamp,date_default_timezone_get());
} else {
return Carbon::createFromTimestamp(0, date_default_timezone_get());
This one fix issues with soap when commands are scheduled
An issue has been logged for this here: 4.5.1: a **repeating** Command event stops every player on that display getting its schedule · Issue #3931 · xibosignage/xibo · GitHub
Thank you
Hey,
This has been fixed in v4.5.2 which has just been released. You can find the release notes here.
Thanks ![]()
