I want to integrate videos, bute the Xibo Player won’t show the layout.
The server is running on Version 3.0.3. The Client (W10 22H2) is running Xibo Player Version 3.301.1 .
The layout has only one region. In this region, there is one video. In the preview everything seems to work fine.
The layout is scheduled always.
Xibo Player shows only the default Layout. The video can be played local with Windows Media Player.
Here are some logs. I assume the layout ist marked as invalid, because the media (video) failed.
Thank you!
With this in mind I would recommend trying a different codec to see if this resolves your issue. I find a good way to test video playback is to use Handbrake to convert your video to a 720p fast or 1080p fast preset, and to make sure to set the file to be MP4 when it is re-encoded.
I’ve been having some problems regarding windows 10 and the H265 codec (HECV) on my devices.
To resolve I simply installed this codec on my devices.
Here is the link where I downloaded it (Pay attention if your computer is 32 or 64 bits):
I even made a command to run on the client via the CMS if you want:
