I have a layout that has 4 web page contents, but when WAN connection drops while displaying this layout, it is frozen, no longer displays the web page content. The layout appears only background.
In the error log, it appears that the player could not resolve the DNS name from which the web pages are hosted. The solution right now is to restart the player.
This may be a bug? In the display profile configuration, the setting for “default duration of empty layouts” is set to 7.
Xibo Server version 1.7.4 in Ubuntu 14.04 LTS.
Display: Windows 7 SP1 x32 with Xibo Player version 1.7.3.
If there is no connection to those webservers then you’re right the Player won’t be able to show the content. It should however recover once the connection is available again.
Hey Alex,
My apologies if it seemed like I was complaining, I was only pointing out I’ve reported the same issue. I truly appreciate the work you all do.
The thread was on your old forum and I never ported it to the community.
Create a webpage media type with the URL http://invalid.xibo.org.uk
What happens in that case? Is it the same behaviour as if there’s no WAN connection?
Only the black background appears. It freezes nothing.
In which case it’s working exactly as it should. The webpage is blank because it’s not a valid URL. At the end of the 10 seconds, it moves to the next media item.
