is it somehow possible to receive the sourcecode or .tar.gz which you can usually clone via github for the following xibo for Linux version: 1.8 r7 240 ?
Thanks in advance!
Cheers
Chris
Thanks in advance!
Cheers
Chris
1.8 has been abandonwared.
Hey, I do know that. v240 was pushed on the edge channel. On that channel 4.0.0 got released some weeks ago. 1.8 r7 240 worked fine for me and i need that version again. That’s why I’m asking.
On github, different edge versions are found in the archive: Releases · xibosignage/xibo-linux · GitHub
I could try to build that version with snapcraft again I guess..
I see. Maybe try to contact directly someone from Xibo snap dev team.
I will try that. Thank you for your response.
