My problem is that the Xibo player displays no content on a Windows PC. A view of the “client information and status” shows the following errors:
Unable to Create new videoObject: Class not registered. (Excluding HRESULST: 0x080040154 (REGDB_E_CLASSNOTREG))
Prepare layout failed: Exception raised what: Specified argument is out of range. Parameter name: Unable to set and start a media node.
Layout change to … failed. Exception raised what: Specified argument is out of range. Parameter name: Unable to set and start a media node.
I already have two displays with Xibo in use. at the problematic display is a new installation of Xibo Player (additional Display)
I had no problems with the other displays except this one.
What are the meanings of those error messages and how do I fix them
Xibo CMS is still “Base Configured”. Except for layouts and displays nothing was changed
installed version is 1.7.7 on all displays. All displays are Win10 clients. IE11 is also installed and configured as default browser.
There are no empty regions, there is one region over the entire screen which is to play a video from the library.
The installation of the player ran smoothly
The Display ist also logged in to the CMS. There is no default layout configured to the display. Screen profile ist set to Windows (but the other screens doesn’t have that configured).
I have installed everything in the same way as all other displays. I don’t know the fault.
UI Thread|02.07.2016 13:48:06|Error|Region - Eval Options|Unable to create new video object: Klasse nicht registriert (Ausnahme von HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
UI Thread|02.07.2016 13:48:06|Error|MainForm - ChangeToNextLayout|Prepare Layout Failed. Exception raised was: Das angegebene Argument liegt außerhalb des gültigen Wertebereichs.
Parametername: Unable to set and start a media node
UI Thread|02.07.2016 13:48:06|Error|MainForm - ChangeToNextLayout|Layout Change to C:\Users\admin\Documents\Xibo Library\16.xlf failed. Exception raised was: Das angegebene Argument liegt außerhalb des gültigen Wertebereichs.
It should be something simple, that’s not often changed.
So default layout should work as a backup layout when there is nothing scheduled / scheduled layout being downloaded / there is a problem with scheduled layout.
