Xibo Player Clock Flip Broke
I have two fire tv’s running the Xibo Player for Android and for some reason when using the Clock Flip Widget It gets all distorted. Any ideas on how to fix this? It works on the windows Xibo Player just not on the Android one.
Hi RicoSuave679,
Sorry to hear about the issue. I would love to investigate this issue for you and replicate it on my end. Is it okay if I can obtain a copy of your exported layout with the ‘Clock Flip ’ widget? If so, please respond to my DM with the exported copy of your layout. Furthermore, could you please share the needed information below?
  • What is the version of the CMS you are using?
  • What is the version of Xibo for the Android player you are using?
  • What is the exact model of your firestick?
Hope to hear from you soon!
Kind regards,
Jerry
