I recently tested Xibo on a novoDS device and noticed that shell commands were not working.
Then I went into the settings of the app and tried to grant the Xibo app root privileges, but it told me that superuser privileges were not available.
The thing is that there is no login, or session on that device and no other way to be root, expect in a terminal I downloaded.
Just wanted to know if you ever heard of that problem and if you have a way to fix it ?
