I just figured out that if I copy the shared folder of the Xibo on my other machine I found this error :
Same as the other error, none of the solution on other topics worked
Hi, I guess it just took a bit of time for the docker to come up, I’ve made a lot of Xibo installs since then and they all took 3-10 minutes to work after I typed the command… So maybe it wasn’t related at all to spamming the command
thanks, yes, same experience, usually 3-5 minutes but this took 1 h and no solutions. So I downgraded to 2.2.3 again with sql import. Than it works but version 2.3.0 did not work.
