I´ve installed the latest xibo cms server (2.1.2) on nginx. The cms works fine so far, but I can´t save any setting. I get a 405 error on saving. I´ve tried different nginx configurations, which I found here, but no configuration works. This is my last nginx config state:
server {
listen 80;
listen [::]:80;
server_name xibo.xy.de;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
ssl_certificate /etc/letsencrypt/live/xibo.xy.de/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/xibo.xy.de/privkey.pem;
add_header Strict-Transport-Security "max-age=63072000; includeSubdomains; preload";
access_log /var/log/access.log combined;
error_log /var/log/error.log;
root /var/www/xibo/htdocs/xibo/web;
index index.php index.html index.htm;
location / {
try_files $uri $uri/ @rewrites;
location /api/authorize {
try_files $uri /api/authorize/index.php?args;
location /api {
try_files $uri /api/index.php?$args;
location /install {
try_files $uri /install/index.php?$args;
location /maint {
try_files $uri /maint/index.php?$args;
location /maintenance {
try_files $uri /index.php?$args;
location ~ \.php {
try_files $1 = 404;
include /etc/nginx/fastcgi_params;
fastcgi_split_path_info ^(.+\.php)(/.+)\$;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
#fastcgi_param SCRIPT_NAME $fastcgi_script_name;
#fastcgi_param HTTPS on;
fastcgi_pass unix:/var/run/php/php7.3-fpm-xibo.sock;
fastcgi_index index.php;
# This is for a proper working of WSDL clients
if ($request_method = 'OPTIONS') {
add_header 'Access-Control-Allow-Origin' "$http_origin";
add_header 'Access-Control-Allow-Methods' 'GET, POST, OPTIONS';
add_header 'Access-Control-Allow-Headers' 'DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,MessageType,SOAPAction';
add_header 'Access-Control-Max-Age' 1728000;
add_header 'Content-Type' 'text/plain charset=UTF-8';
add_header 'Content-Length' 0;
return 204;
if ($request_method = 'POST') {
add_header 'Access-Control-Allow-Origin' '*';
add_header 'Access-Control-Allow-Headers' 'DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type';
if ($request_method = 'GET') {
# To enable nginx direct file downloads
location /download {
internal;
alias /var/www/xibo/library;
Has anyone a hint? It should be possible to run this software with nginx, shouldn´t it?
boris
October 31, 2019, 8:17pm
2
I’m also running into the 405 error, but I am running IIS 10 and Xibo 2.1.0. I posted a topic on it yesterday, hoping to find a resolution soon. Good luck.
This is my profile, you can try it out
server {
listen 80;
server_name xibo.ito.fyi;
root /var/www/xibo/web;
client_max_body_size 500M;
client_body_timeout 1200;
error_page 500 502 503 504 /50x.html;
error_log /var/log/nginx/xibo_error.log error;
access_loe /var/log/nginx/xibo_access.log main;
location / {
location = 50x.html {
root /usr/share/nginx/html;
location ~ /.php$ {
fastcgi_apss unix:/run/php/php7.4-fpm.sock;
fastcgi_param SCRITP_FILENAME $document_root/$fastcgi_script_name;
include fastcgi_params;
location ~/\.ht {
den all;
location /api {
try_files $uri /api/authorize/index.php?$args;
location /maint {
try _flies $uri /maint/index.php?$args;
try_files $uri /maintenance/index.php?$agrs;
My Xibo
You may also need to execute chmod -R www-data:www-data /var/www/xibo
Thanks - my try files directive was the problem. The fully working host has to be:
server {
listen 80;
listen [::]:80;
server {
location / {
location /api {
location /install {
location /maint {
location ~ \.php {
try_files $uri =404;
fastcgi_param SCRIPT_FILENAME $document_root/$fastcgi_script_name;
return 204;
internal;
