I’m trying to solve an issue with javascript, but the solution is not working on the client.
Background:
We’re a language school and for every day of the year there is a phrase that we want to display and explain. This includes a little youtube video.
Every day I pull in the relevant info into a dataset. Showing the various text fields is done with dataset views.
Showing the video is turning out to be more tricky: I’ve got it in an ‘Embedded’ region and have followed some code example posted on these forums. However I can’t hardcode the youtube video ID in the javascript (ID is different every day).
To get this to work I’ve added some javascript to an ‘Embedded’ element and a ‘Dataset View’ element (same layout, different
regions). It works correctly when previewing (tested on IE11, Firefox and Chrome - Windows 10) but not on
my Windows (Win10) client.
In the embedded element I set up a function (onYoutubeVideoID) that gets called when the video ID is available:
console.log("ihb debug1"); // javascript for embedded youtube video var player; var youtubevideoid = window.top.ihbpotdyoutubeid; //youtubevideoid = "zySOzxsc3WA"; if (typeof(youtubevideoid) == "undefined" || youtubevideoid === null) { // Get ID console.log("ihb debug3"); window.top.onYoutubeVideoID = onYoutubeVideoID; } else { console.log("ihb debug2"); var tag = document.createElement('script'); tag.src = "https://www.youtube.com/iframe_api"; var firstScriptTag = document.getElementsByTagName('script')[0]; firstScriptTag.parentNode.insertBefore(tag, firstScriptTag); } function onYoutubeVideoID() { console.log("ihb debug4"); youtubevideoid = window.top.ihbpotdyoutubeid; var tag = document.createElement('script'); tag.src = "https://www.youtube.com/iframe_api"; var firstScriptTag = document.getElementsByTagName('script')[0]; firstScriptTag.parentNode.insertBefore(tag, firstScriptTag); } function onYouTubeIframeAPIReady() { console.log("ihb debug5"); player = new YT.Player('player',{ height: '720', width: '1280', videoId: youtubevideoid, playerVars:{ 'playlist': youtubevideoid, 'loop': 1, 'controls' : 0, 'rel' : 0, 'fs' : 0, 'showinfo' : 0, 'cc_load_policy' : 0, 'iv_load_policy' : 3, 'modestbranding' : 1 }, events:{ 'onReady': onPlayerReady } }); } function onPlayerReady(event) { console.log("ihb debug6"); event.target.playVideo(); } function EmbedInit() { // Init will be called when this page is loaded in the client. return; }
The function gets called from the javascript linked to the dataset view element:
var youtubeidelement = document.getElementById(“span_1_1”);
var youtubeidval = youtubeidelement.innerText;
youtubeidelement.style.display = “none”;
console.log("ihb debug5 " + youtubeidval );
window.top.ihbpotdyoutubeid = youtubeidval;
window.top.onYoutubeVideoID();
If I uncomment:
//youtubevideoid = “zySOzxsc3WA”;
everything works fine on the client.
Any tips or suggestions welcome.
Marcel
International House Bristol
