Hallo togehther,
i try to install xibo 1.7.9 on a Synology NAS DS 216j. iI have copy the unzip file into the web folder and then i write in internet explorer 192.168.2.100/xibo/install.php
Then the first mask i see and there i have many misstakes you can see with an “x”:
File System Permissions - Write access required for settings.php and install.php
SOAP Extension - PHP SOAP extension required to function.
Gettext - PHP Gettext support to function.
Large File Uploads - You probably want to allow larger files to be uploaded than is currently available with your PHP configuration.
We suggest setting your PHP post_max_size and upload_max_size to at least 128M, and also increasing your max_execution_time to at least 120 seconds. -
Internationalization - International Support for formatting Dates, Numbers, etc.Translations will still function without this PHP module, however dates, times and numbers will not be shown in your locale.
The php.ini i had open it with the config file editor for synology and the php.ini looks like so:
[PHP]
engine = On
short_open_tag = On
asp_tags = Off
precision = 14
output_buffering = 4096
zlib.output_compression = Off
implicit_flush = Off
serialize_precision = 17
disable_functions =
disable_classes =
zend.enable_gc = On
expose_php = Off
max_execution_time = 240
max_input_time = 60
memory_limit = 128M
error_reporting = E_ALL & ~E_NOTICE & ~E_STRICT & ~E_DEPRECATED
display_startup_errors = Off
log_errors = On
log_errors_max_len = 1024
ignore_repeated_errors = Off
ignore_repeated_source = Off
report_memleaks = On
track_errors = Off
html_errors = Off
variables_order = "GPCS"
request_order = "GP"
register_argc_argv = Off
auto_globals_jit = On
post_max_size = 128M
default_mimetype = "text/html"
default_charset = "UTF-8"
include_path = "."
extension_dir = "/usr/lib/php/modules"
sys_temp_dir = "/var/services/tmp"
enable_dl = Off
file_uploads = On
upload_tmp_dir = "/var/services/tmp"
upload_max_filesize = 128M
max_file_uploads = 20
allow_url_fopen = On
allow_url_include = Off
default_socket_timeout = 60
But the other misstakes i don´t find the right.
Please can you say me the right way how i can fix the problems in step by step
Kussel
