I am trying to install Xibo on my CPanel environment hosted on OVH. I have uploaded all the files and am trying to sort out the php extensions but am not succeeding. I have enabled the extensions within the PHP SOAP section of Cpanel but I am not sure where to put the line of code whereby xibo looks for the extensions. CPanel state
"Using Your PHP Extension(s) and Application(s)
You will need to add “/home/rchallis/php” to the include path. You can do this by adding the following code to your script:
ini_set(“include_path”, ‘/home/rchallis/php:’ . ini_get(“include_path”) );"
Is anyone able to help?
Thanks in advanced.
