We have just released our latest Xibo for Android release. This release comes with two media player support updates, and one fix.
Media Player Support
Amazon Signage Stick: deeper device integration with support for Amazon RDM API: serial number, mac address, reboot, screenshot, screen on, screen off, mute, unmute
DSDevices: Remove special handling for the DSDA1 and treat it as a rooted device (the device is not Xibo certified)
I’m having an issue with the latest release on my devices, I have the DSCS9X and DSDA1 and they periodically crash and fail to auto restart the app. I had no issues on 408 and 409, rolling back to 409 has worked for us. Not sure if anyone else has reported this issue?
I ran into the same issues with my DSCS9X devices after updating them through the CMS. I ended up making a post about it, and later figured out a workaround to resolve this.
Thank you for your response, sounds like you’ve had a similar issue!
I’ll take a look and see if this is something I want to do, I don’t want to rely too much on custom scripts so I may just roll back to 409 until a fix comes out. I’ll report the error as I have a log for it and see if that helps the dev team.
