I have installed Xibo 1.8.3 on a GoDaddy VPS. Everything has been working fine I thought until I tried to use the Embedded module. I click on the Embedded module in the Region Timeline and I can enter anything or nothing into the HTML to Embed it doesn’t matter, when I click save I’m brought to a white page with just this text: Tue, 02 Jan 2018 04:12:56 GMT, I’m assuming its the current server time. I click the back button and everything goes back to normal but the embedded module won’t work. I ran on debugging mode and looked at the logs while I was recreating the problem and they showed nothing at all to help. Weird uh!! Please help.
That is rather odd, I’m not sure what can cause this, that being said there should be some logs about it, especially with CMS in Test mode / debug log level.
Is the webpage module working correctly?
Here a screenshot of when I click save on the embedded module.
Also the webpage module is working just fine.
Would me posting a log dump help?
I will posting a log dump and also installing a older xibo to see if the issue persists.
You can send the logs to me via private message please.
It would be best to have the CMS in the test mode or at least with the audit log enabled and then recreate the issue to see the logs about it - ie you will want to go through Report Fault Wizard please.
SoooO it turns out upon install of a older version of Xibo on my webserver, I was presented with a screen telling my I was not allowed to install this because it was blocked by “Wordfence”. I also have wordpress installed on my webserver which as a plugin called “Wordfence”. It seems like this plugin scans my whole webserver and blocks different types of attacks: It viewed Xibo as a threat!!!,
I disabled the plugin and the Embedded module worked right away lol!!
All I need to do now is figure out how to whitelist my actions on Wordfence!!!
Thanks Peter for looking at my post!
I see, I didn’t know that you have other services running there as well, but I’m glad you were able to find out what was causing the problems with embedded widget.
