Specify the full CMS version you are using, including the revision number.
Installation Method
Docker over Dockge
Operating System
Debian 12 on Proxmox 8.3.0
My webinterface is responding very slow.
The system itself does not show high CPU or RAM or IO usage.
I used Dockge to install the system.
docker stats:
Proxmox stats:
services:
cms-db:
image: mysql:8.0
volumes:
- ./shared/db:/var/lib/mysql:Z
environment:
- MYSQL_DATABASE=cms
- MYSQL_USER=cms
- MYSQL_PASSWORD=password
- MYSQL_ROOT_PASSWORD=password
mem_limit: 2g
env_file: config.env
restart: always
cms-xmr:
image: ghcr.io/xibosignage/xibo-xmr:1.0
ports:
- 9505:9505
restart: always
mem_limit: 512m
cms-web:
image: ghcr.io/xibosignage/xibo-cms:release-4.2.2
volumes:
- ./shared/cms/custom:/var/www/cms/custom:Z
- ./shared/backup:/var/www/backup:Z
- ./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:Z
- ./shared/cms/library:/var/www/cms/library:Z
- ./shared/cms/web/userscripts:/var/www/cms/web/userscripts:Z
- ./shared/cms/ca-certs:/var/www/cms/ca-certs:Z
restart: always
environment:
- MYSQL_HOST=cms-db
- XMR_HOST=cms-xmr
- CMS_USE_MEMCACHED=true
- MEMCACHED_HOST=cms-memcached
ports:
- 80:80
mem_limit: 2g
cms-memcached:
image: memcached:alpine
command: memcached -m 15
restart: always
mem_limit: 200M
cms-quickchart:
image: ianw/quickchart
restart: always
networks: {}
