Xibo Docker migration from one Machine to another
i am trying to migrate xibo docker application from one machine to another machine in my computer.
when i do docker ps it shows me 2 Containers
i have copied both of them and loaded into another machine.
now how should i run both containers, any linking is their for running both containers simultaneously in coordination with each other to run successfully.
or shall i start both containers individually.
Please help!!
Thank you for the information. You do not need to copy the containers to migrate your CMS to another machine. I would recommend deleting those Containers and starting the migration again, as they will not work using the method you have described.
To Migrate your Docker CMS, follow the below instructions:
  • Down the Containers on the original machine using the docker-compose down command.
  • Zip or Tar compress the folder that contains the installation.
  • Copy the archive to your new machine and extract it to the location you wish to install it into.
  • Up the Containers using the docker-compose up -d command.
docker-compose will then create and link all 3 containers, using your original configuration files.
If you have any issues with the migration, let me know.
