Guys,
Hope you’re doing well.
My client is looking to migrate XIBO CMS from cPanel to Docker, is there any documentation available for this?
Thank you
Ameya
Guys,
Thank you
Ameya
Hi Ameya,
We recommend this guide : https://xibo.org.uk/docs/setup/upgrade-and-switch-to-xibo-for-docker-install
All the best!
Thank you for the guide.
So I followed the guide carefully and able to login docker installation with the old username and password but displays are not showing in the dashboard, is this something you could help with?
