I am trying to install Xibo CMS v1.8.0 but I am unable to install it.
I do not find any install.php file into the root of the Xibo folder…
Anyone can tell me how to install Xibo v1.8.0 ?
Thank you,
Thank you,
Here you can find installation manual - http://xibo.org.uk/manual-tempel/en/release_notes_1.8.0-rc2.html
We do recommend docker installation.
Thank you for helping.
I succeed to install Xibo 1.8.0 on port <my_ip>:8080
I am now trying to create a python script which communicate with XIbo API.
I have followed the tutorial http://xibo.org.uk/2014/02/19/scripting-xibo-content-management-a-brief-tour-of-the-api/
In the past, I was succeeded in creating a python script with Xibo v1.7.9
BUT I do not succeed to creating one with Xibo 1.8.0-rc2 …
I get an Error 404.
Herebelow :
Traceback (most recent call last):
File “ReplaceVideo.py”, line 114, in
api = XiboAPI.XiboAPI()
File “/var/www/html/CMS-script/xibo_com/1.8.0-rc2/XiboAPI.py”, line 71, in init
user_token, user_secret = self.setupUserToken(url,consumer_key,consumer_secret)
File “/var/www/html/CMS-script/xibo_com/1.8.0-rc2/XiboAPI.py”, line 101, in setupUserToken
raise Exception(“Invalid response %s.” % resp[‘status’])
Exception: Invalid response 404.
The consumer_secret key seems to be very long … Is that normal ?
Could you help me please ?
That bried tour of the api is an old article regarding 1.7 API.
For 1.8 please see http://xibo.org.uk/manual-tempel/en/api.html
and my API Introduction with Postman
Yes, client_secret is rather long ![]()
You should find asnwers to your question in manual pages and/or my API introduction topic.
If you’d have more questions, please feel free to ask.
Thank you for your answer,
I have followed your tutorial until “Application Configuration”.
I do not understand what Postman stand for…
Actually,
I need to create a Python or PHP script which manage my players through Xibo API.
How can I do it ?
SHall I use Postman?
Thanks,
You don’t need to use Postman, although I personally find it very suitable, that’s why it’s in my guide, but you can use any application to communicate with the CMS API - http://xibo.org.uk/manual-tempel/en/cms_api.html
In all cases, you will need to create a new application in CMS and then use clientId and clientSecret along with access_token call to gain access to API.
