You either need to upgrade from 1.7.9 to 1.8.13 in place, and from there on to 2.2.3, or you can install a new 1.8.13 and move your data to that.
Assuming you’re going to switch to Docker at the same time, then we have notes on moving to Docker which will work for going to 1.8.13, and then you can directly upgrade that to 2.2.3 very easily. So you’d do a fresh install of 1.8.13 and import your data leaving your original server alone, and then upgrade that. The notes explain it in detail.
Our recommendation is Ubuntu 18.04 or 20.04. Assuming SLES has up to date packages for Docker and docker-compose then I see no reason it ought not to work on SLES too, but we’ve never tried it. There may be others here to do run on SLES.
Thanks Alex for all your help. We were able to install and migrate data from our old test server.
The production has data thrice of test system therefore we want to make sure it doesn’t create issues for the existing system during data migration from old prod server to new prod server. Do you have any recommendation? users may create new layouts when migration is happening.
You can’t have users making changes to the system while you migrate. You need to arrange a downtime window sufficient to do the migration (based on your test) and time to roll back if it doesn’t work out
If the hostname of the server will change (ie the URL you use to access the CMS changes) then you’d need to change the configuration on all your players (and at the same time upgrade them).
If the URL to access will stay the same then you’d just need to upgrade the Player version on each of your Player devices. The configuration will stay the same.
You can prevent users accessing the old CMS by stopping your webserver on that server - so for example by stopping Apache. Then take your MySQL backup and a copy of the library which will be in a consistent state.
We’re planning to use the different host name/URL so that we don’t interfere with existing CMS.
Yes, we would need to update players to point to the new server address and we will upgrade the players during that time.
We have a lot of layouts therefore we would like to verify/preview all the layouts in production first before connecting players to the new server and display those layouts.
What we need to know - Should we bring the existing CMS down during content migration from old server to new server?
ok, Thanks Alex. I was in impression that since we are just copying content from existing server to new server therefore we can keep the existing CMS running. Even if someone creates a new layout during that time on existing server, we can import it manually on new server.
But looks like we would need to bring the existing CMS completely down.
Thanks for your help.
After upgrading to 2.3.5 from 1.8.13, all the displays are missing. Dashboard shows the number of displays but the display screen is missing all the displays.
Can you please help?
We did a fresh installation of 1.8.13, did the content migration and they upgraded to 2.3.5.
Did we follow the correct sequence or it doesn’t matter if we do the migration first or the upgrade first.
