Xibo CMS - 3.0.0-alpha Released
We are pleased to announce the release of our first development preview for the 3.0 version of Xibo. The codename for this version is “Finlay”.
This is a companion discussion topic for the original entry at https://blog.xibo.org.uk/3-0-0-alpha-released/
Just installed this to check out some of the new features and it looks like it’s going to really open up a lot of functionality which is great! I can’t preview anything though, I’ve tried to create a couple of different layouts, even the simplest single region single widget, but when loading the preview none of the regions show up. I understand the concept of the widget drawer now, though it would be nice to see it working in the preview.
Thank you for bringing this to our attention, an issue has been created for this:
It would be great to get your thoughts on the widget drawer once you can see it working in the preview :slight_smile:
great to see xibo does the next steps. :clap:
i would also like to test, but in our case i need the cms itself since we host it in our wampp installation.
is there a chance to get the cms of the 3.0.0 beta as well?
regards
Masterbug
Hello everyone,
I´ve pulled the Xibo 3.0.0-alpha2 version from docker hub. With the “docker run” operator I´ve tried to start it, but it don´t work:
"Waiting for MySQL to start - max 300 seconds
MySQL started
ERROR 2005 (HY000): Unknown MySQL server host ‘mysql’ (-2)
New install
Provisioning Database
Phinx by CakePHP - https://phinx.org. 0.9.2
using config file .varwwwcmsphinx.php
using config parser php
using migration paths
- /var/www/cms/db/migrations
warning no environment specified, defaulting to: production
using adapter mysql
using database cms
In MysqlAdapter.php line 115:
There was a problem connecting to the database: SQLSTATE[HY000] [2002] php_
network_getaddresses: getaddrinfo failed: Name does not resolve
migrate [-c|–configuration CONFIGURATION] [-p|–parser PARSER] [-e|–environment ENVIRONMENT] [-t|–target TARGET] [-d|–date DATE] [-x|–dry-run]
Configuring Database Settings
Setting up Maintenance
Protected Maintenance
Importing ca-certs
cp: can’t stat '/var/www/cms/ca-certs/.pem’: No such file or directory*
cp: can’t stat '/var/www/cms/ca-certs/.crt’: No such file or directory*
WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
Setting up Quickchart
Configuring Maintenance
crontab: can’t open ‘/etc/crontabs/apache’: Permission denied
Starting cron
Starting webserver
AH00558: httpd: Could not reliably determine the server’s fully qualified domain name, using"
Did I forgot something?
I need to test the 3.0.0-alpha2 version because of the new interaction feature.
Can enyone post a step by step guide how to install this version from docker hub?
Hey every one,
i have also install the Alpha3 release to test the new functions.
the important function for me ist the interactive Layout.
But it doesn’t work for me.
The “action-drawer” is empty and i can not great any interactions.
is the problem a layer eight problem or a bug?
Maybe someone could explain how it work to creat a interactiv layout?
Thanks!
Please see the following topic:
How does this work if all I want to do is display a website from a single domain? Say xibo.org.uk. Are all the links clickable/tapable? How does scrolling and gestures work?
