We are pleased to announce our first release for the 2.3 version of Xibo. The codename for this version is “Wolf”.
This is a companion discussion topic for the original entry at https://blog.xibo.org.uk/2-3-0-released/
I upgraded from 2.2.0 to 2.3.0 but for some reason i don’t have the new layout designer.
Docker installation on Ubuntu.
Edit: On Internet Explorer it does show the new designer.
Cleared Cache in Chrome and the new designer showed up.
I have a lot of issue with V2.3.0 new fresh install, on CMS.
I have a lot of Layout not found?
I also try clear browser, and it work to start with, but after 3 to 4 time i have the same issue.
Now i am up to /layout/designer/5 and same issue.
I also have problems with bagrund image? on most of them it will not show?
another issue is i am trying to edit a layout now but i cant edit? it only show me a green screen
I have upgrade from 2.2.0 to 2.3.0 using Docker on Windows and i don’t have new layout designer. I have cleared cache in Chrome but nothing change.
I am not sure why you would have those issues - we’d be happy to help if you’re able to open a new topic in “Get Help” and provide some more details for the error.
Does the version number say 2.3.0 on the login/about pages?
Sorry. It is old version 2.2.3.
It appears the upgrade failed then - we are aware of an upgrade issue and will be releasing 2.3.1 asap to fix.
I just have upgraded from 2.2.3 to 2.3.0 without any problem. I only have to press Ctrl+F5 to reload page and get new layout designer.
Worth noting that, at least in FF, Ctrl-F5 reloads all components of a page, cached images, JS and CSS, in addition to the HTML; that’s likely in play there.
A post was split to a new topic: Problem with the Countdown Widget
