i installed cms-2.0.0-rc1 with manual install , after install firstly click the settings ,but get 500 error , other links working .is anyone faced this problem, any solution ?
Could you enable CMS debugging (report fault page) and then check the Log page for detailed information about the error please?
hi peter , i did it 2-3 times ,but unfortunately not find any solution, i prepared newest one ,it like …
logId,runNo,logDate,channel,page,function,message,display.display,type
1848,cdd15a6,“2019-03-13 16:29:55”,WEB,/,GET,“Loading 1. All Objects = 0”,DEBUG
1849,cdd15a6,“2019-03-13 16:29:55”,WEB,/,GET,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1850,cdd15a6,“2019-03-13 16:29:55”,WEB,/,GET,“CMS font CSS returned from Cache.”,DEBUG
1851,cdd15a6,“2019-03-13 16:29:55”,WEB,/,GET,“Showing the homepage: 29”,DEBUG
1852,cdd15a6,“2019-03-13 16:29:55”,WEB,/,GET,“Checking permissions against the logged in user: ID: 1, Name: admin, UserType: 1”,DEBUG
1853,cdd15a6,“2019-03-13 16:29:55”,WEB,/,GET,“Request stats: {
" default" : {
" select" : 7
" log" : {
" insert" : 5
" length" : 0.0865309238433837890625,
" memoryUsage" : 4408112,
" peakMemoryUsage" : 4438216
}.”,INFO
1854,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“Loading 1. All Objects = 0”,DEBUG
1855,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1856,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“CMS font CSS returned from Cache.”,DEBUG
1857,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“Checking permissions against the logged in user: ID: 1, Name: admin, UserType: 1”,DEBUG
1858,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“Checking permissions against the logged in user: ID: 1, Name: admin, UserType: 1”,DEBUG
1859,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“Checking permissions against the logged in user: ID: 1, Name: admin, UserType: 1”,DEBUG
1860,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“Checking permissions against the logged in user: ID: 1, Name: admin, UserType: 1”,DEBUG
1861,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“UserOption navigationMenuPosition not found”,DEBUG
1862,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“UserOption hideNavigation not found”,DEBUG
1863,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“UserOption navigationMenuPosition not found”,DEBUG
1864,e5d6bdc,“2019-03-13 16:29:55”,WEB,/statusdashboard,GET,“Request stats: {
" default" : {
" select" : 9
" log" : {
" insert" : 10
" length" : 0.11149692535400390625,
" memoryUsage" : 4633264,
" peakMemoryUsage" : 4716056
}.”,INFO
1865,66af092,“2019-03-13 16:29:55”,WEB,/library/fontcss,GET,“Loading 1. All Objects = 0”,DEBUG
1866,66af092,“2019-03-13 16:29:55”,WEB,/library/fontcss,GET,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1867,66af092,“2019-03-13 16:29:55”,WEB,/library/fontcss,GET,“CMS font CSS returned from Cache.”,DEBUG
1868,66af092,“2019-03-13 16:29:55”,WEB,/library/fontcss,GET,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1869,66af092,“2019-03-13 16:29:55”,WEB,/library/fontcss,GET,“CMS font CSS returned from Cache.”,DEBUG
1870,66af092,“2019-03-13 16:29:55”,WEB,/library/fontcss,GET,“Request stats: {
" default" : {
" select" : 6
" log" : {
" insert" : 5
" length" : 0.0911290645599365234375,
" memoryUsage" : 4406368,
" peakMemoryUsage" : 4439016
}.”,INFO
1871,3e3fa61,“2019-03-13 16:29:55”,WEB,/clock,GET,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1872,3e3fa61,“2019-03-13 16:29:55”,WEB,/clock,GET,“CMS font CSS returned from Cache.”,DEBUG
1873,3e3fa61,“2019-03-13 16:29:55”,WEB,/clock,GET,“Request stats: {
" default" : {
" select" : 1
" log" : {
" insert" : 2
" length" : 0.0993340015411376953125,
" memoryUsage" : 4291216,
" peakMemoryUsage" : 4364672
}.”,INFO
1874,c09dbfb,“2019-03-13 16:29:56”,WEB,/user/pref,GET,“Loading 1. All Objects = 0”,DEBUG
1875,c09dbfb,“2019-03-13 16:29:56”,WEB,/user/pref,GET,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1876,c09dbfb,“2019-03-13 16:29:56”,WEB,/user/pref,GET,“CMS font CSS returned from Cache.”,DEBUG
1877,c09dbfb,“2019-03-13 16:29:56”,WEB,/user/pref,GET,“Request stats: {
" default" : {
" select" : 4
" log" : {
" insert" : 3
" length" : 0.0845148563385009765625,
" memoryUsage" : 4418936,
" peakMemoryUsage" : 4461936
}.”,INFO
1878,a4091e5,“2019-03-13 16:29:56”,WEB,/statusdashboard/displays,GET,“Loading 1. All Objects = 0”,DEBUG
1879,a4091e5,“2019-03-13 16:29:56”,WEB,/statusdashboard/displays,GET,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1880,a4091e5,“2019-03-13 16:29:56”,WEB,/statusdashboard/displays,GET,“CMS font CSS returned from Cache.”,DEBUG
1881,a4091e5,“2019-03-13 16:29:56”,WEB,/statusdashboard/displays,GET,“Checking permissions against the logged in user: ID: 1, Name: admin, UserType: 1”,DEBUG
1882,a4091e5,“2019-03-13 16:29:56”,WEB,/statusdashboard/displays,GET,“Request stats: {
" default" : {
" select" : 6
" log" : {
" insert" : 4
" length" : 0.0831239223480224609375,
" memoryUsage" : 4419152,
" peakMemoryUsage" : 4481384
}.”,INFO
1883,d49920e,“2019-03-13 16:29:56”,WEB,/user/pref,POST,“Loading 1. All Objects = 0”,DEBUG
1884,d49920e,“2019-03-13 16:29:56”,WEB,/user/pref,POST,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1885,d49920e,“2019-03-13 16:29:56”,WEB,/user/pref,POST,“CMS font CSS returned from Cache.”,DEBUG
1886,d49920e,“2019-03-13 16:29:56”,WEB,/user/pref,POST,“Checking permissions against the logged in user: ID: 1, Name: admin, UserType: 1”,DEBUG
1887,d49920e,“2019-03-13 16:29:56”,WEB,/user/pref,POST,"Saving user. User admin. userId: 1, UserTypeId: 1, homePageId: 29, email = ",DEBUG
1888,d49920e,“2019-03-13 16:29:56”,WEB,/user/pref,POST,“Request stats: {
" default" : {
" select" : 6,
" insert" : 1,
" commit" : 1
" log" : {
" insert" : 5
" length" : 0.0923640727996826171875,
" memoryUsage" : 4420816,
" peakMemoryUsage" : 4466600
}.”,INFO
1889,bee3771,“2019-03-13 16:30:02”,WEB,/admin/view,GET,“Loading 1. All Objects = 0”,DEBUG
1890,bee3771,“2019-03-13 16:30:02”,WEB,/admin/view,GET,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1891,bee3771,“2019-03-13 16:30:02”,WEB,/admin/view,GET,“CMS font CSS returned from Cache.”,DEBUG
1892,bee3771,“2019-03-13 16:30:02”,WEB,/admin/view,GET,“Found /var/www/vhosts/cmshuawei.com/signage.cmshuawei.com/web/theme/compact”,DEBUG
1893,bee3771,“2019-03-13 16:30:02”,WEB,/admin/view,GET,“Found /var/www/vhosts/cmshuawei.com/signage.cmshuawei.com/web/theme/default”,DEBUG
1894,bee3771,“2019-03-13 16:30:02”,WEB,/admin/view,GET,“Checking permissions against the logged in user: ID: 1, Name: admin, UserType: 1”,DEBUG
1895,ade15fa,“2019-03-13 16:30:14”,WEB,/fault/collect,GET,“Loading 1. All Objects = 0”,DEBUG
1896,ade15fa,“2019-03-13 16:30:14”,WEB,/fault/collect,GET,“Install Fonts called with options: {" invalidateCache" :false}”,DEBUG
1897,ade15fa,“2019-03-13 16:30:14”,WEB,/fault/collect,GET,“CMS font CSS returned from Cache.”,DEBUG
but , it s so strange that , settings not working , just install the script , not any modification ,or anything…
