Client sometimes displays this error message
This client constantly changes status between tick and cloud. The client does not work with XMR.
In addition, in the server library in the directory widget, are constantly the Directories and the files rewritten.
Does anyone have an idea what this could be ?
Best regards
Hubert
If you select Tasks in your CMS and click the down facing arrow at the end of the Widget Sync Task. Choose Edit from the drop down menu and confirm what the schedule is set to please.
*/3 * * * *
For testing, I turned off XTR. It also happens when XTR is off.
