Hi Peter,
So when I worked on it a little bit more and got the same error. As you suggested; I looked in to event viewer for error and this couple of errors occurred. What should I do?
1st ERROR
Log Name: Application
Source: .NET Runtime
Date: 08.03.2016 11:19:34
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: xiboplayer
Description:
Application: XiboClient.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Reflection.TargetInvocationException
Stack:
at System.RuntimeMethodHandle.InvokeMethod(System.Object, System.Object[], System.Signature, Boolean)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(System.Object, System.Object[], System.Object[])
at System.Reflection.RuntimeMethodInfo.UnsafeInvoke(System.Object, System.Reflection.BindingFlags, System.Reflection.Binder, System.Object[], System.Globalization.CultureInfo)
at System.Delegate.DynamicInvokeImpl(System.Object[])
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
at System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.ScrollableControl.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Form.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Control+ControlNativeWindow.OnMessage(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Control+ControlNativeWindow.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef)
at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext)
at System.Windows.Forms.Application.Run(System.Windows.Forms.Form)
at XiboClient.Program.RunClient()
at XiboClient.Program.Main(System.String[])
Event Xml:
1026
2
0
0x80000000000000
3588
Application
xiboplayer
Stack:
2nd ERROR
Source: Application Error
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Description:
Faulting application name: XiboClient.exe, version: 2.0.0.0, time stamp: 0x56aa14cd
Faulting module name: KERNELBASE.dll, version: 6.1.7601.19135, time stamp: 0x56a1c79e
Exception code: 0xe0434352
Fault offset: 0x0000c52f
Faulting process id: 0xf1c
Faulting application start time: 0x01d17916b6d0ce6a
Faulting application path: C:\Program Files (x86)\Xibo Player\XiboClient.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
Report Id: defab3f3-e50e-11e5-a86f-3464a92fa617
Event Xml:
1000
2
100
0x80000000000000
3589
Application
xiboplayer
XiboClient.exe
2.0.0.0
56aa14cd
KERNELBASE.dll
6.1.7601.19135
56a1c79e
e0434352
0000c52f
f1c
01d17916b6d0ce6a
