Can you please tell me how do we setup the Xibo client to shutdown automatically during off hours and start in the morning and keep it shut down on the weekends ? We have recently bought it and we are planning to implement it and I am learning it right now, but this is something I need to know ASAP.
So you will want to use shell commands, first you’ll have to enable them:
In CMS, modules page, find and enable shell command module
In CMS, display settings, edit display profile that your device is using, on a advanced tab, tick the ‘Enable Shell Commands’ checkbox.
Now you’ll want to create special layout(s) with shell command module item in a region.
Add the commands you wish to run (it uses cmd.exe)
Schedule that layout on your device
Hmm I am not sure why I thought that you are using Windows client, but the same logic apply to Android client
the difference is that you will use Linux commands.
Shell command module has 2 fields
Windows
Android/Linux
Is there a way to switch the Auto Startup off on an android device.
I installed the App to for demonstration purposes. But now on activating the device screen Xibo always pop’s up.
Great for Display purpose but no so graet for my tablet.
Yes, please go to Display settings Page in CMS,
Go to Advanced tab
uncheck ‘Start during device start up?’
