How to enable shell command module?
Hi, It the post below you advised to enable the shell commands module in order to send commands to the display/pc.
But, in the modules sections. the shell command is not enable and I do not see how I could enable it.
I don’t think the clear cache is related.
Thanks,
Theodoros
I assume you’re using Spring Signage hosting?
If so the shell commands module is disabled by default, we can enable it for you, please contact our support via email.
Thank you Peter! I will do it.
Theodoros
