Xibo and Spotify
When inserting new regions are you able to add a region which will show spotify and play spotify while your main signage takes place in another region?
It should be possible to embed song/album/playlist in an iframe in embedded html module in Xibo.
Interesting, I’m looking for a solution to put background music, but the problem I see is that Spotify does not allow the “Autoplay”.
Autoplay
Is there an auto-play option on the widget?
No, there is not. The user has to start playback by clicking on the Play Button, which will open the web player or desktop client to start the playback.
Does anyone know if this can be solved?
If they don’t allow it, then I’m afraid it is not possible ( I did not look if they have any API documentation for that though), there are some online radios that start playing when you visit a webpage that will work in Xibo, you could have a YouTube video/playlist added to layout with autoplay, that should also work.
