Xibo 2.0.0 manual installation
Dear all,
I have downloaded the beta version of xibo 2.0.0 and tried to install it manually, but I get a blank screen. I’m trying to install it as I did with 1.8 version.
I can’t use dockers so I would like to know if I’m missing something regarding the installation (php version,etc).
Regards,
Rebeca
As mentioned in the Xibo Blog, this release of the 2.0.0 beta is for Docker installations. The files needed for a non Docker setup will be released at a later date.
