This is a cosmetic issue/bug only.
To replicate
Modify a DataSet config on its ‘Advanced’ tab and change ‘Truncate DataSet’ from ‘Never’ to ‘Always’.
Select ‘View Data’ and page through the current data set.
Wait for the data set to be refreshed and truncated by the cron task (in my case, the task is run every 5 minutes and on the next run, the data set was truncated from 850 entries to 50)
A manual browser page refresh leaves you on a blank page (beyond the end of the now-truncated data set), with an odd readout - in my case ‘Showing 161 to 50 of 50 entries’.
Expected behavior:
A sanity check realises the view is beyond the end of the data set and resets it to start at entry #1 (if any).
