I have installed composer, and downloaded from GitHub the 1.8 series.
when running php composer.phar install it states
" Composer could not find a composer.json file in C:\xibobeta
To initialize a project, please create a composer.json file as described in the https://getcomposer.org/ “Getting Started” section "
can run " composer install " and it shows error :
" Loading composer repositories with package information
Installing dependencies (including require-dev) from lock file
Your requirements could not be resolved to an installable set of packages.
Problem 1
- Installation request for react/zmq v0.3.0 -> satisfiable by react/zmq[v0.3.0].
- react/zmq v0.3.0 requires ext-zmq * -> the requested PHP extension zmq is missing from your system.
Problem 2
- xibosignage/xibo-xmr dev-develop requires react/zmq ^0.3.0 -> satisfiable by react/zmq[v0.3.0].
- Installation request for xibosignage/xibo-xmr dev-develop -> satisfiable by xibosignage/xibo-xmr[dev-develop].
Any help is appreciated.
Thank you in advance.
LOL a zip file of the 1.8 series would have been handy, just sayin’
