add-apt-repository "deb [arch = amd64] https://download.docker.com/linux/ubuntu $ (lsb_release -cs) stable"
E: The download of some index files failed, they were skipped, or the old ones were used instead.
14.0 KB received in 5s (2,365 o / s)
W: Can not Recover https://download.docker.com/linux/ubuntu/dists/jessie/stable/binary-amd64/Packages HttpError404
root @ Debian: / # apt-get install docker-this
Reading package lists ... Done
Building the dependency tree
Reading status information ... Done
E: Can not find the docker package-this
Do you have any idea about the origin of this problem?
root@Debian:/# apt-get install docker-ce
Lecture des listes de paquets… Fait
Construction de l’arbre des dépendances
Lecture des informations d’état… Fait
E: Impossible de trouver le paquet docker-ce
Looking again I don’t think you’ve followed their guide properly. You have “ubuntu” in your repository URL, and their guide for Debian doesn’t use that at all.
my serveur is :
root@Debian:/var/lib# uname -r
3.16.0-4-amd64
I think that the problem is related to the list sources.list which does not contain the good urls of the mirroires considering the fact that I am in France.
Do you have an idea of what I can do to unlock this problem?
here is the contents of my /etc/apt/sources.list file
# Debian Jessie, dépôt principal
deb http://deb.debian.org/debian/ jessie main
# Debian Jessie, mises à jour de sécurité
deb http://security.debian.org/ jessie/updates main
# Debian Jessie, mises à jour "volatiles"
deb http://deb.debian.org/debian/ jessie-updates main
W: Impossible de récupérer https://download.docker.com/linux/ubuntu/dists/jessie/stable/binary-amd64/Packages1 HttpError404
So, I suspect you have an Ubuntu repository configured as well. Try looking in /etc/apt/sources.list.d and in that directory, see if any of the files there reference that URL.
I get the message:
root @ Debian: / opt / xibo # add-apt-repository \
“deb [arch = amd64] https://download.docker.com/linux/$ (. / etc / os-release; echo” $ ID ")
$ (lsb_release -cs) \ stable "
Traceback (most recent call last):
File “/ usr / bin / add-apt-repository”, line 95, in
sp = SoftwareProperties (options = options)
File “/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py”, line 109, in init
self.reload_sourceslist ()
File “/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py”, line 599, in reload_sourceslist
self.distro.get_sources (self.sourceslist)
File “/usr/lib/python3/dist-packages/aptsources/distro.py”, line 93, in get_sources
(self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: Could not find a distribution template for Debian / n / a
