I’ve read the other support topics that seemed to be about the same problem but as of right now none made my setup work.
My CMS (1.8.10 on ubuntu 16.04) works behind https://example.org/xibo with this nginx configuration :
location /xibo/ { proxy_pass http://192.168.1.114:80/xibo/; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Proto $scheme; client_max_body_size 20M; }
The problem I have now is that for some reason my clients do not receive media from the CMS.
I have tried with a client in the LAN and it works, but the moment the client is outside and has to go through the reverse proxy, nothing shows up.
The display (in the CMS) status goes between
and
, while inside the manager all the files have a
except the clock (that was downloaded so it’s a ![]()
I do not have XMR setup, I just don’t know how to make it work in my setup.
Collect interval is at 5 minutes for testing, it is habitually at 1hr as layout are rarely updated.
I have a 1.7.6 working setup, my goal is to upgrade it.
There are no error logs. The nginx server only gives me access logs :
172.16.0.19 - - [24/Oct/2018:11:19:54 -0400] "GET /api/v1/channels.list?access_token=5629dc63e660b111575950ea144aea42e85c3652&count=0&sort=%7B+%22ts%22%3A+-1+%7D&offset=0 HTTP/1.0" 200 1787 "-" "Zapier" 172.16.0.19 - - [24/Oct/2018:11:19:55 -0400] "POST /xibo/xmds.php?v=5&method=registerDisplay HTTP/1.0" 200 2934 "-" "Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000)" 172.16.0.19 - - [24/Oct/2018:11:19:56 -0400] "POST /xibo/xmds.php?v=5&method=notifyStatus HTTP/1.0" 200 514 "-" "Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000)" 172.16.0.19 - - [24/Oct/2018:11:19:56 -0400] "POST /xibo/xmds.php?v=5&method=schedule HTTP/1.0" 200 4254 "-" "Mozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000)" 172.16.0.19 - - [24/Oct/2018:11:20:02 -0400] "GET /xibo/clock?_=1540394221486 HTTP/1.0" 200 194 "https://example.org/xibo/campaign/view" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.100 Safari/537.36" 172.16.0.19 - - [24/Oct/2018:11:20:02 -0400] "GET /xibo/login/ping?_=1540394221487 HTTP/1.0" 200 169 "https://example.org/xibo/campaign/view" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.100 Safari/537.36"
The CMS, with debugging ON, logs gave me :
701 ee222a9 2018-10-24 10:41 WEB /fault/view GET "Request stats: { "default": { "select": 7 }, "log": { "insert": 3 }, "length": 0.147169828414917, "memoryUsage": 9220608, "peakMemoryUsage": 9322392 }." INFO 702 c2ae352 2018-10-24 10:41 WEB /library/fontcss GET Loading 1. All Objects = 0 DEBUG 703 c2ae352 2018-10-24 10:41 WEB /library/fontcss GET Install Fonts called with options: {"invalidateCache":false} DEBUG 704 c2ae352 2018-10-24 10:41 WEB /library/fontcss GET CMS font CSS returned from Cache. DEBUG 705 c2ae352 2018-10-24 10:41 WEB /library/fontcss GET Install Fonts called with options: {"invalidateCache":false} DEBUG 706 c2ae352 2018-10-24 10:41 WEB /library/fontcss GET CMS font CSS returned from Cache. DEBUG 707 c2ae352 2018-10-24 10:41 WEB /library/fontcss GET "Request stats: { "default": { "select": 6 }, "log": { "insert": 5 }, "length": 0.1419830322265625, "memoryUsage": 8400176, "peakMemoryUsage": 8454088 }." INFO
The Client has :
(media waiting to be downloaded all at 0%)
