Xibo 1.8.0 - Library Add Media
A very specific JPG file causes problems when uploading to the library.
Media_ID: 32
troubleshoot.zip can be made available.
#22 {main}",,DEBUG
139,0bd478b,"2017-04-06 10:57:06",WEB,/library/download/32,GET,"Unable to read image from file (C:\xibo-library\hubert\32.jpg). Exception Type: Intervention\Image\Exception\NotReadableException",,ERROR
140,0bd478b,"2017-04-06 10:57:06",WEB,/library/download/32,GET,"Request stats: {
    "default": {
        "select": 8
    "log": {
        "insert": 12
    "length": -0.7036
}.",,INFO
141,65db462,"2017-04-06 10:57:13",WEB,/clock,GET,"Install Fonts called with options: {"invalidateCache":false}",,DEBUG
142,65db462,"2017-04-06 10:57:13",WEB,/clock,GET,"CMS font CSS returned from Cache.",,DEBUG
143,65db462,"2017-04-06 10:57:13",WEB,/clock,GET,"Checking permissions against the logged in user: ID: 0, Name: , UserType: 0",,DEBUG
144,65db462,"2017-04-06 10:57:13",WEB,/clock,GET,"Route drawer not viewable",,DEBUG
145,65db462,"2017-04-06 10:57:13",WEB,/clock,GET,"Blocked assess to unrecognised page: /drawer.",,DEBUG
146,65db462,"2017-04-06 10:57:13",WEB,/clock,GET,"Request stats: {
    "log": {
        "insert": 5
    "default": {
        "select": 1
    "length": 0.1404
}.",,INFO
147,18b5b2b,"2017-04-06 10:57:21",WEB,/fault/collect,GET,"Loading 1. All Objects = 0",,DEBUG
148,18b5b2b,"2017-04-06 10:57:21",WEB,/fault/collect,GET,"Install Fonts called with options: {"invalidateCache":false}",,DEBUG
149,18b5b2b,"2017-04-06 10:57:21",WEB,/fault/collect,GET,"CMS font CSS returned from Cache.",,DEBUG
The error suggest that there was a problem reading the file.
Does C:\xibo-library\hubert\32.jpg exist?
Yes, the file exists and can also be opened
Is it able to be read as the user your webserver is running as?
Yes, as it also works with the other media
If it’s always that particular file, perhaps there’s something in the way that file is encoded that means the PHP libraries that deal with image processing can’t work with it. Try opening it in a photo editor (GIMP, PhotoShop etc) and re-saving it.
After saving it with IrfanView it works
