J’avais un xibo 1.8.2 qui fonctionnait très bien.
J’ai voulu passer à xibo 1.8.10
j’ai télécharger l’archive , mais que je lance la commande
docker-compose up -d
j’obtiens une erreur de certificat (voir ci-dessous)
Que faire ?
Pour info, j’utilise une debian à jour
Linux 4.9.0-6-amd64 #1 SMP Debian 4.9.88-1+deb9u1 (2018-05-07) x86_64 GNU/Linux
When I try to update xibo from 1.8.2 to 1.8.10, I have an error.
Pulling cms-web (xibosignage/xibo-cms:release-1.8.10)…
ERROR: Get https://registry-1.docker.io/v2/: x509: certificate is not valid for any names, but wanted to match registry-1.docker.io
I am using a
I have find the solution.
The problem come with the proxy.
It seems docker can’t go threw a https proxy.
So in fact the only solution is to put the computer on an other network without proxy just for the update…
alex
3
You can do it that way, or you can use an out of band transfer for the images:
Run the following on an internet connected computer
docker pull xibosignage/xibo-xmr:release-0.7
docker pull xibosignage/xibo-cms:release-1.8.10
docker pull mysql:5.6
docker save xibosignage/xibo-xmr:release-0.7 > xmr.tar.gz
docker save xibosignage/xibo-cms:release-1.8.10 > cms.tar.gz
docker save mysql:5.6 > mysql.tar.gz
Then transfer the three tar.gz files to your server, and run
docker load -i xmr.tar.gz
docker load -i cms.tar.gz
docker load -i mysql.tar.gz
Thne you can up the containers in the normal way, and the images will be pre-downloaded for you.
