good morning
I wanted to know if the Twitter Module can block words or images that are inappropriate
Thank you
regards
good morning
Thank you
regards
You use the standard operators https://developer.twitter.com/en/docs/tweets/search/guides/standard-operators.html
I don’t think there is any “profanity filter” per se for Twitter, I might be wrong though.
Thanks Peter!!
Regards,
