Could you please let me know?
Hi gta11011311.
What CMS version are you using? I’m aware of an issue that was resolved in 4.3.0 and 4.3.1. With this in mind, do you find the issue is solved in 4.3.1?
As @DanBW has mentioned, we did identify a bug which has now been fixed: Replace/Expire Media: Unable to delete expired media after replacement · Issue #3654 · xibosignage/xibo · GitHub
Therefore upgrading to the latest version should fix the issue you are experiencing.
Could I also ask that you try to refrain from creating duplicate posts for the same issue as it makes it harder for the community to keep track when following, I have linked here ![]()
Thank you
