Why is my twitter feed not showing on my player?
Hi
I am using Xibo 1.7.9 and I have put a twitter feed on a screen. It runs correctly on preview but there is just a blank space on the screen itself.
It seems like it won’t download that region.
How can this be solved?
Would be nice to see screenshot of status window on your player, perhaps it will make everything clear(er).
Please press ‘i’ on your keyboard while Xibo for Windows has focus.
It seems that there is one file still to download (you’d need to scroll that window to see what has 0% completion) - presumably that will be twitter resource.
I wonder if it has problems writing to your local library, could be worth to try and change it to the default library location ie C:\Users\<USERNAME>\Documents\Xibo Library
I assume this layout Id 53 is valid? (checkmark in status column in CMS)
Hi the twitter feed has now appeared but none of the images are showing?
