Hello I have some strange things happening with my Xibo setup.
I’m running Xibo cms 2.3.6 on linux in docker container and my android is a dscs9 with latest android version. I have almost every day white planes on my screen were there should be text or other things.
So it is a very simple setup no special things.
I hope anyone can help
I have a campaign setup with more layouts and they all show the same white planes.
Only the rtsp streams shows correct.
Powering the android dscs9 on and off does help but that is a bit difficult because the Monitor is mounted in a box for anti theft purposes.
My first setup was stolen.
On a side note, if accessing your Player is difficult you could set up a ‘reboot command’. This is covered in one of our online training courses, available here: https://training.xibosignage.com/p/admin-essentials which is free to all users.
Already found the solution to the reboot problem. Enabled XMR in the display profile settings and enabled port 9505 in the firewall.
Now the command “svc power reboot” works fine.
Back again, same problem yesterday I again had those white areas in my regions were supposed to be should be text.
This is after one week of no problems at all.
I just did an update now to android V207.
Should I leave surface view disabled or not ???
You can upload your export on https://transfer.xibo.org.uk and then paste the link here - we will get it from there. If you’d rather noone else saw it you can PM the link to Natasha.
SurfaceView (in Display Settings Profiles) only effects Video Widgets and has no effect on images, text, etc.
All text in Xibo is shown as web content, meaning the white squares (which you’ve said are text) will be trying to run in little embedded web browsers.
It looks to me like the embedded browser is missing completely, as opposed to being loaded but empty. In either case this shouldn’t happen.
As this is a commercial player, if you’d rather contact the Help Desk (support.xibosignage.com) then you are very welcome to do that - your response on there will be quicker than on this community forum. We monitor it as much as we can, but its a community rather than a support system.
That’s the same as I see. It was running for a week and suddenly I had those white areas. This was after I disabled surface view. With surface view enabled I had these white areas almost every day. After the update to R207 android version I didn’t had the problem so far.
