White planes with xibo on android
Thanks for the update, very interesting - please let us know if you encounter the issue on R207.
Hello Again. I did an upgrade to version 208 but now the problem with the white areas is back.
I want to downgrade to version 207 but this doesn’t work. If I select the 207 version and do a refresh its still on 208. Even after a reboot…
Please advice how to downgrade to V207
You would need to re-upload the 207 APK to the CMS (you can only install one APK one time). I’d encourage you to try v2 R210 instead though: https://blog.xibo.org.uk/xibo-for-android-v2-r210-available/
Hello Dan, Yes I already did install the r210 version. Since then I had no problems anymore. Running fine now for almost a week
