White border with Powepoint!
I’m trying to get a powerpoint to show on a tv and the powerpoint is only viewing in the top left hand side with a white border around the rest! It is also showing dragging capabilites but wont enlarge. I have tried changing the ratios which dosent make a difference.
Help anyone!?!?
Thanks,
Nathalie
What’s your layout resolution?
What’s screen resolution?
What CMS and player version are you using?
Also if you’re using Windows 10, this might be another issues with powerpoint - https://blogs.technet.microsoft.com/askcore/2016/08/16/display-scaling-changes-for-the-windows-10-anniversary-update/
