What web browser is used in xibo for android
Hi
Which browser is used in Xibo for Android and what is its specifications and capability (HTLM5, CSS, Elementor elements etc)
Thanks in advance for any help
Regards
Micke
We use the Android WebView available through the device firmware, and so the revision is dependent on the device you’re using.
You should be able to see the Android WebView from the list of installed apps, or you can point Xibo to a layout containing one of the “what browser am I using” tools.
If you’re using a DSCS95/X:
Device Operating System Browser Engine
DSCS9X Android 9 Chrome for Android 85
DSCS95 Android 9 Chrome for Android 99
Thanks,
Dan
Hi Dan, thanks a lot. Would you please explain a bit more about the following which you wrote
" or you can point Xibo to a layout containing one of the “what browser am I using” tools."
Thanks in advance
Micke
Create a layout with a web page widget on it, pointing to https://www.whatsmybrowser.org/ and when that runs on your device it will reflect the web engine in use.
