Hi all can somone tell me the ports that xibo uses.
It really depends on how you configure it.
Assuming you use the defaults, then
HTTP 80/tcp
XMR 9505/tcp
If you configure SSL
HTTPS 443/tcp
Between the CMS and the XMR server, also
50001/tcp
However if you’re using Docker or running XMR and the CMS on the same server, then they communicate over private networks/loopback network and so won’t require firewall rules.
