We can’t answer that for you. It depends entirely on what local DNS records you’ve added to your DNS server.
If you don’t have a DNS server, or haven’t added any DNS records, then you would need to use the IP address, which would be something like http://10.10.120.25 assuming you installed at the root of the webserver.
If you have web in the URL you need to use to log in to the Xibo server, then the CMS is incorrectly installed and you need to go and resolve that before moving forward. Specifically please see the section of the manual concerned with preparing your environment: https://xibo.org.uk/manual-tempel/en/install_environment.html
Thanks for the reply Alex!
You are right, I need to use the “web folder” in order to reach my admin xibo via web.
I will look into the URL you have me.
