Hi everyone,
I’m trying to install and test webOS app, but I ran on an issue which I don’t know how to debug/fix.
My setup is:
Docker install v1.8.3 running behind nginx ssl reverse proxy.
WebOS player running on 32SM5D-B
I followed your installation guide and it went OK. Player is able to connect to CMS, but it fails to download a bunch of resources with error 47. On the CMS side, player is shown as logged in but there are a bunch of these in the log:
9854 60dcec4 2017-12-25 20:05 PLAYER POST ERROR webOS [parseRequiredFiles] downloadERROR Download failed for file xibo-webpage-render.js. Error:Failed to download file with error code 47
Server side is working correctly, I confirmed it with windows player, although It could be something that I messed up since this is an installation I’m using as my playground…
Anyways, any help will be greatly appreciated.
Thank you,
Ivan
