Web page playlist "stops and restarts" at end
Time and date are UTC on the server & player, synced with NTP.
Xibo for Windows 406.3-win32-x86
I have a very simple layout which has a ticker, clock and webpage carousel using the webpage widget with a playlist inside.
On V3, the carousel restarts seamlessly from the last item back to the first. On V4, there is a momentary (5 second) completely black screen (not even the ticker and clock are displayed) between the last item, and the first appearing again. The selected options on each URL are: Preload? (which doesn’t actually seem to (sufficiently) preload the page, it is still loading when it appears), Open Natively, Set a duration, and the duration length (either 30 or 60 seconds depending on the item).
I have nothing interesting in the logs, at Error level.
Any advice? Am I approaching the whole thing wrong, and should accomplish the carousel in a different way?
