Reported bugs still persist in 2.0.2. When uploading an exported layout from 1.8.12 to 2.0.2 I get an ‘Internal Server Error’ (Xibo 2.0.1 Layout not found and import layout not working second bullet). When using the weather forecast presets (and customizations) the layout isn’t right (Weather styling not correct).
Reported issues when exporting a layout were fixed in 2.0.2 and we didnt experience any issues with regards to Weather and therefore need further information from you to look into your case further and so have moved your post to the support category.
I understand that one of our support agents has contacted you regarding a layout export and once we have that we can investigate further for you.
Thank you
