When I add my api key to the weather module, the module will pull down a forecast but it’s not the weather for my area. Logs show that the curl GET command is as follows:
Actually I think I got this figured out. Didn’t see the option to input custom lat,long under the configuration tab of the module itself in the layout designer.
That is right - if you choose to “Use Display Location” it will use the lat/long you set on your Display and the preview in the CMS will use the CMS lat/long from settings.
Useful if you have Displays in more than one location and want to show the same Layout with local weather.
