Is it possbile chage the letter to open the watchdog?
Now if I open xibo player and press the letter “i” opens the watchdog.
I would like to open it with “ctrl + letter” for example
best regards
best regards
Change this in your CMS,
menu ‘Display Settings’
Create or Edit your Windows display profile
Troubleshooting
Thanks for the reply.
Do you know if it’s possible use special characters? (-, , ", etc…), I’m trying to use them but tehy don’t work.
I’m using the last versione of CMS / Player
