Watchdog error System.IO.IOException
Hello Xibo Team,
We have exactly the same problem.
Client : Windows 2.1.201 - Intel Brix Windows 10 Home
Server : 2.2.3 - Apache2
Randomly, some players are freezing. We can’t do a CTRL+ALT+SUPP to kill the process. Here are errors of the Watchdogs :
System.IO.IOException: The process cannot access the file ‘C:\Users\BRIX\Documents\Xibo Library\status.json’ because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access)
at XiboClientWatchdog.Watcher.Run()
