Hi
I would like to get any stat info using API, i already succeed to get display and layout info
But when i tried to get stat info like sample at swagger
i got null brace like picture below
So anyone can help me to solve this issues ??
Thank you
Which version of the CMS are you using please?
@ifarzana - does the request look right?
i’m using CMS 1.8.13
sorry for my late response
and let’s pray the best for the world
Thank You
I’m really not sure why that wouldn’t work, it seems reasonable to me. Can you enable logging and get a report fault for it?
Hi Dan,
what kind report do you want ?
from console ? or from where ?
i’ll wait your response as soon as possible
thank you
The CMS has a page for troubleshooting called the Fault page where you run through some steps and download a file. Under the advanced menu, called “Report Fault”
That is what I mean.
Thanks,
Dan
ok.
i’m not at front of my PC and my player
i’ll go to Report Fault, and back to you as soon as possible
thank you
